thinking about upsizing tires on my B2500 van
Old May 6, 2012 | 04:46 PM
blackvan's Avatar
blackvan
Originally Posted by rsdata
blackvan,
I respectfully have to disagree with your assessment of 225/235/245 being load ranges... these numbers I believe represent tire sizes measured in mm of tread across the width with the /75 designation indicating that 75% of that width is in the side wall depth. Therefore increasing the width also increases the tire height (diameter). My van door sticker specifies LT tires at 65#/50# (rear/front) pressure, so I am not changing from P tires to LT tires. I am sticking with LT tires I currently as three different tire stores says that I have to with this weight van. My van actually handles fairly well with the stiff sidewalls.
The only problem that I can see is that the tires are worn fairly thin right down the middle, but have good side tread left. I attribute that to driving the van lightly loaded by the previous owner. Previously this was a work van for a painter, who carried paint and tools and occasionally towed a small trailer, but I doubt ever carried the weight that this van was designed to carry.
THis website http://www.csgnetwork.com/tiresizescalc.html pretty clearly spells out the relationship of tire size to circumference and diameter of various tire sizes. By using LT245 tires instead of LT225 tires, I will increase the circumference of the tire by 4% while also increasing the tread width.
Going through the numbers again…
225 size = 92 inches circumference STOCK tire size
235 size = 93.8 inches circumference or about 2% longer distance travelled per each tire revolution
245 size = 95.7 in circumference or about 4% longer per revolution of the tire… if I multiply a 4.10 ratio by 96% (the amount of revolution that a 245 tire will roll to go the same distance as a 225 size) then I get an effective rear ratio of 3.936
Dismissing extra rolling resistance of the fatter tire, I am hoping to get UP TO 2% to 4% better MPG with these larger tires. BUT THEN AGAIN I am hoping my assumptions are correct and that is what I am asking for help with using this forum.
I stand corrected. The old US tire size system used A- N load ranges which do not correspond to tire diameter. The metric tires are indeed a specific size. Based on info at tire rack, it appears that:
225/75-16 is 29.3
235/75-16 is 29.8
245/75-16 is 30.5
The difference in diameter amounts to 683 revolutions per mile vs 735 is .93 so the number I get is 7%. The increased tread width will increase rolling resistance so I think in this case you might just break even. The tread wear would seem to indicate that you aren't fully loading the current tire and going to 245 will exacerbate that contact patch (tire wear) issue. I think you will have to run them at lower pressure to correct it and obviously that won't help gas milage.
The profile or aspect ratio ( 235/75 )is actually a ratio of sidewall height to section width. The section height's measurement can be calculated by multiplying the section width by the aspect ratio. So at a given size an aspect ratio of 60 is always going to be shorter (smaller diameter) than the 75.
I installed Michelin LTX MS/2 P235/75-15 (XL load rating) on mine. They aren't cheap but they are worth it. Excellent tires in the rain and after 10k miles the tread still looks like new.
A set of ring and pinion gears is $255 - $550 online and another $200 for the kit. The cheaper gears are ok but are a lot louder and they don't recommend them for vans. You could probably get this done professionally for $900 or just find a differential and swap it out for half that. If you don't need the torque from your 4.11's, a set of 3.5 gears will certainly increase your gas milage and you can still tow. My 2000 5.2L swb van, overdrive, 3.5 gears, Chrysler Corporate rear end gets at least 18mpg highway with 1,000 lb payload. That is at 70 - 75mph with the A/C on.
Old May 6, 2012 | 05:14 PM
blackvan's Avatar
blackvan
Originally Posted by Supradude
I had Goodyear Silent Armors until just recently when some lame vandal decided to knife tires up and down our street.
Man.. I am sorry, thats awful!
I have a super-sensitive alarm, multiple video cameras and alert neighbors but none of that would have prevented this. It is sad that some jerk with nothing better to do can inflict $1,000 worth of damage in less than 60 seconds. I am fortunate at the moment to have a garage that my van will fit into but I realize many people simply don't have that option.
Old May 7, 2012 | 06:06 PM
rsdata's Avatar
rsdata
Default Stev, clarification needed
Stev, you mentioned in a post
Next, drain our the rear OEM oil and replace with Redline synthetic 75W90 per the Chrysler TSB. This helps with wear life and MPG.
I stopped today at NAPA and asked how much oil to buy for my diff case... the reply was 2.2 QTS of 75W90 EXCEPT if I have the DANA M60 and in that case use straight 90 weight...
At that point I stopped getting the 75W90 because I know my hood sticker refers to the Dana 4.10 M60/24 rear end.
So my question is... well do I leave the 90 weght in there? Do I drain and reinstall new after 155,000 miles? I have never heard of replacing rear end oil... but then again there is lots I don't know.
Any thing you can add to this NAPA info?
thanks again for the help
Old May 8, 2012 | 01:12 AM
stev's Avatar
stev
So my question is... well do I leave the 90 weight in there? Do I drain and reinstall new after 155,000 miles? I have never heard of replacing rear end oil... but then again there is lots I don't know.
At the DTR forums, the 75W90 SYNTHETIC is the preferred diff oil to use in the Dana M60.
Ford puts 75W90QL SYNTHETIC in the Dana M60 on the front 4x4 axle as OEM. And Ford uses the same in the Econoline vans in the rear.
Per the Chrysler TSB-03-08-00, NOTE: THIS BULLETIN APPLIES TO ALL VEHICLES EQUIPPED WITH AN 8.25, 9.25, OR C205F CORPORATE AXLE.
Old May 23, 2012 | 09:02 AM
rsdata's Avatar
rsdata
Default all fixed up and nowhere to go
Well I did it... I went to local Goodyear dealer and bought top of the line Wrangler Silent Armor LT245X75-16 tires to put on the B2500 extended van. The fronts just clear the sway bar. I went with these tires but it was a toss up with the Michelin LTX M/S bqsed on reviews I read on tirerack.com . In the end I decided to use the local tire store as the manager there talked nice to me and gave me a good deal, plus $80 + $80 (using their credit card) so $160 rebate brought the cost per tire down below what Sams and equal to what Tirerack offered. He also offered to make sure that the larger size would work and gave me a 30 day TEST RIDE to make sure. Otherwise he would swap out to the stock LT225 size if the 245 size would not fit.
I looked at many of the things that Stev posted to increase mileage, and changed rear diff fluid to 75W90, greased front wheel bearings, changed front brake hoses. I found the rear brakes were put together incorrectly and would not adjust, but with the help of a master mechanic friend who pointed out the error of how the cable was attached, I got everything working in the rear brakes now and got them adjusted properly. I now have great brake pedal and she stops on a dime.
NOw I need a place to go to see what kind of MPG I will get. If there is no improvement, I won't be totally disappointed, as I like having good quality new tires under me, and knowing that all of the brakes and mechanicals are as good as I can get them.
I will report in a couple of weeks when I take a 500 mile round trip to central TN and back to Cincinnati in that van. Thanks to everyone that gave great input to this decision.
Old May 23, 2012 | 08:49 PM
Supradude's Avatar
Supradude
I think you'll be pleased with the Goodyears especially in the unfortunate instant you have to slam on those good working brakes and turn at the same time to avoid something. I made up a saying back in the seventies after a hydroplaning crash on cheap tires in the rain when I was only going 55. No matter how much money your vehicle cost, there's only one thing between your butt and the road, your tires, never ever go cheap on tires.
Old May 24, 2012 | 11:39 PM
stev's Avatar
stev
It will be a hard pressed issue for good MPG with the wider tires. Been there, done that. Had a better MPG and tire improvements going to a higher load range.
Report back your findings.
Old May 26, 2012 | 03:36 AM
DoubleWasp's Avatar
DoubleWasp
You mean 245/75/16 isn't the OEM size? I've had E-Rated 245/75's on my van since I bought it. Love them to death, and get great fuel economy, and even wear with a great ride at 55 psi.
Old May 26, 2012 | 03:48 AM
rsdata's Avatar
rsdata
Default stock size tires for my rig
The sticker on my door panel specifies LT225x75-16 tires at 50# and 65# pressure. I have the '01 B2500 extended work van (no windows or rear seating), 8-lug wheels with the step bumper and B3500 frame underneath. I like the larger tires that I just got so far (LT245) and hope to get good road grip from them, plus long mileage. By upping the size I hope to get an effective higher ratio rear end (stock is 4.10). I calculate the larger diameter tires give me an effective 3.93 ratio, hopefully giving me a bit more MPG on the highway. At current gas prices +1MPG boost would be a benefit. I currently have them pumped to 50/65# but may change that to 55# as you mention, as I do not carry any great loads in the rear.
Old May 26, 2012 | 11:36 AM
DoubleWasp's Avatar
DoubleWasp
Need to check my door panel now to see what mine says.
