low beam headlights not working
Old May 4, 2012 | 01:20 AM
2bTim's Avatar
2bTim
Question low beam headlights not working
hi all, I have a 1997 Dodgeram Van 2500 5.2L, and the low beam headlights are not working, but the high beam headlights work fine. I'm not sure where to start troubleshooting this problem. Any help will be greatly appreciated!
Old May 4, 2012 | 04:41 AM
blackvan's Avatar
blackvan
Assuming you have checked all fuses this typically means the headlight switch is bad. Check the bulbs, check the headlamp wiring. If all appears good then pull and examine the switch for signs of damage.
