Dual battery system
Old Dec 22, 2014 | 08:33 AM
blackvan's Avatar
blackvan
Old Dec 23, 2014 | 08:51 AM
funair02's Avatar
funair02
Looking forward to the results!
Old Feb 23, 2015 | 09:20 PM
blackvan's Avatar
blackvan
Old Feb 24, 2015 | 07:01 AM
daguvena88's Avatar
daguvena88
Sounds like a fun project.
Is the new aux/optima battery run in parallel, with the switch between the engine battery and aux battery?
If so you may wanna google 'mismatched batteries parallel', as this setup supposedly can shorten the life of your either battery. In this case the mismatch is presumably age, deep cycle vs starting, amp hours, etc. I suppose this is a YMMV situation.
EDIT: having gone back reread the posts, its evident you're familiar with this already.
Alternative setups are
1. use a battery selector switch (A, B, A/B, OFF) to manually isolate the batteries altogether. perhaps this is the intent of the setup you're going with i'm not sure the disconnect switch you linked would allow you to truly isolate one battery from the other.
2. use a solid state isolator / smart battery isolator (non-diode, no voltage drop)
you can search boat and rv forums blogs, forums for more details.
on that note, those same forums consistently give good reviews of http://www.genuinedealz.com/ for sourcing custom cables. I didn't use them myself but figured I'd throw it out for anyone considering something similar in the future.
Old Feb 24, 2015 | 07:51 AM
blackvan's Avatar
blackvan
Old Feb 24, 2015 | 08:14 AM
daguvena88's Avatar
daguvena88
Originally Posted by blackvan
If you shut off all your batteries completely you will disconnect the pcm, the alarm system, door locks, and the audio head unit "always on" lead which will cause numerous problems
Great point and agreed, that setup was ok for my boat but is not wise in this case.
Old Feb 24, 2015 | 08:54 AM
funair02's Avatar
funair02
sweet set up
nice job
