99 b1500 ram van
Old Jul 2, 2012 | 02:57 PM
zabowalt's Avatar
zabowalt
Angry 99 b1500 ram van
My 99 van just started to blow the starter fuse, I start the van go to the store come out and it wont start, blown fuse, replace & van starts. this happened twice out of 3 times I took it out. (it sits a lot not much usage)
I can start it a numers of times after that but it still blows after a few days of sitting.???
Also when I put the AIR on no air comes out for about a minute than cold air. lately all I get is hot air, when I check air gas it is in the red zone on a home recharger. Is my temp control out of wack? Did a vacume line brake? and the door wont open ????
THANKS FOR ANY HELP
ZABOWALT
Also I have a hard time finding how to post a qoustion is there a easy way to post when I log in?
Old Jul 2, 2012 | 03:36 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
zabo, I just moved this to the proper section. Here you should be able to get a better response. If you have any specific forum questions I may be able to help.
Old Jul 30, 2012 | 07:38 PM
zabowalt's Avatar
zabowalt
I found that the starter fuse has dule use , starter & a/c. I started the van drove and turned the a/c on, got hot air, stoped shut down, could not restart, blowen fuse.
After inspection I found the compressor was not running, clutch would not engage, replaced compressor fixed the problem. Hope this helps somebody else.
ZABOWALT
