1999 Ram 1500 Van 3.9 v 6 Gas gauge malfunction
Old Aug 10, 2012 | 06:52 AM
PhilsHandyService's Avatar
PhilsHandyService
Default 1999 Ram 1500 Van 3.9 v 6 Gas gauge malfunction
I am having a intermittent gas gauge malfunction, replaced in tank pump but still happening it will drop to empty, if I turn the engine of and restart ounce or twice this will some times fix it for a time.
any ideas?
Thanks
Phil's Handy Service, Inc.
State Licensed Residential Contractor
Old Aug 10, 2012 | 11:04 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Since turning the key on and off will affect the gauge, then your problem is likely with the gauge itself. You could try finding an instrument cluster and swapping it out.
Old Sep 8, 2012 | 04:08 PM
PhilsHandyService
Default Changed the cluster: message in the odomiter: no Bus
OK i changed the cluster, now the gas gauge is now working but the engine light is on and a message in the odometer box: no Bus
any ideas!
Old Sep 8, 2012 | 04:35 PM
alloro's Avatar
alloro
any ideas!
1. First try disconnecting the battery for 10 minutes, then reconnect it. Perhaps the PCM is looking for the old cluster.
2. Double check to make sure all of the cluster connectors are in good.
3. It could be a bum cluster.
Old Sep 9, 2012 | 06:37 AM
PhilsHandyService
I changed gauge cluster gas gauge still not working, filled tank and gauge went from 1/4 to E with the light it seems to be going backward
Had the same problem last year thought it was the pump so I changed it.
but that was not it.
any thoughts about were to go from here ?
