Help Fuel pump Troubleshooting
Old Sep 2, 2012 | 07:13 PM
Rambo321's Avatar
Rambo321
Default Help Fuel pump Troubleshooting
Hello Everyone,
I need your Help, I have 1997 Dodge Ram Van 3.9L . The fuel Pump will not work when cranking the engine. I checked the Relay and it's good.
When I jumped two terminals under Relay with a paper clip the Fuel Pump will work and the engine starts. Is there another Fuse or Relay I need to check? Or Is the Computer Bad? oh yeah Fuel Pressure is around 50 psi.
Any Suggestions? Thanks!
Old Sep 2, 2012 | 09:06 PM
sparkzz's Avatar
sparkzz
I ain't no expert, but did you check the ASD relay?
Additionally, jumping the wires at the bottom of the relay just bypasses the relay, it could still be bad.
Old Sep 2, 2012 | 10:05 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Do you get 12 volts across the fuel pump relay coil when attempting to start it?
