Help with lifter -- any ideas or help
Old Sep 19, 2012 | 10:53 PM
landyacht318's Avatar
landyacht318
I do not believe a 5w 20 is spec'd for any Dodge engine of this era. I think stev tried it and had a lot of strange noises.
MMO is about a 10 weight oil. (very thin)
I would not waste the oil you currently have in the engine, but remove the filter, fill a new purolator 30001 filter 5/6 the way with MMO, then install it.
That should bring it down to a heavy 10w 30 weight oil. Oils do vary greatly within their SAE classifications. Some can thin a lot more than others when measured at temperatures above 100C. HTHSv ( High temp high shear viscosity) is measured at 150c and is thought of to be a much more accurate method of measuring viscosity when at temperature.
MMO is really heavy on the phosphorus, and if you burn a lot of oil, this will degrade the CATCON quickly.
If this is a concern Use 0w 20 weight oil in place of MMO.
The Rotella you used already has a lot of ZDDP(Zinc Dialkyl Dithio Phosphate), the P being phosphorus.
Old Sep 19, 2012 | 11:15 PM
blackvan's Avatar
blackvan
Old Sep 20, 2012 | 09:02 PM
funair02's Avatar
funair02
Thanks guys for the suggestions. I think Ill try the MMO and then thinner oil in about 500 miles.
The tick is getting better. I drove the van around about 20 miles today and the tick was there, but about 70% less noticealbe than before.
I am praying it is going the right way now.
The van dosent use or burn any oil and compression is 125+ on all cylinders. It ran good today.
Ill check back in later -- maybe in 4-5 days...I hope to come back with a clean bill of health
Thanks for you help landyacht and blackvan---
BTW nice speaker setup blackvan!
Old Sep 22, 2012 | 01:56 PM
funair02's Avatar
funair02
Just thought you all would like an update.
The tapping has disappeared for now. Strange but true but it is running really really good now.
I have been praying to Jesus that it stays this way. I have gone 60 miles and through 6 starting cycles now with no problem.
It may just be fixed now! Time will tell...
