Transmission Dipstick Tube install
Old Nov 7, 2012 | 05:02 PM
duanebro's Avatar
duanebro
Default Transmission Dipstick Tube install
Do i have to remove the transmission pan to install a new dipstick & tube. Also does the rubber "tophat seal go in from the top of the transmission 1st or do i put it onto the stick & press both in at the same time ?
Old Nov 7, 2012 | 05:21 PM
Hawkstr's Avatar
Hawkstr
very rare you have to remove the transmission pan to install a new dipstick for it. The O-Ring (rubber) I normally install into the hole first before putting the dipstick in.
Just and FYI, might want to put in the info of what you are doing this too.
Old Nov 7, 2012 | 05:46 PM
duanebro's Avatar
duanebro
The part i was sent did NOT have an O-ring, It has a tophat shaped bushing or washer & the tube fits down into it ? 1996 Dodge B-2500 3/4ton 8cylinder Van
Old Nov 7, 2012 | 06:04 PM
Hawkstr's Avatar
Hawkstr
aye so its a grommet not an o-ring, for sure install the grommet first then install the tube.
If you need to you can use some trans fluid or some vaseline to help lube it a little for it to drop in easier
