POWER WINDOW FAILURE 2002 Ram Van
Old Dec 5, 2012 | 02:19 PM
peterfst's Avatar
peterfst
Default POWER WINDOW FAILURE 2002 Ram Van
Both front electric windows on my 2002 B2500 Ram Van just stopped working. Electric shop says fuse is good. Cannot find a relay, under the hood in the black box, that specifies power windows.
Suggestions?
Peter in SLC
Old Dec 5, 2012 | 06:49 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
There are no relays. I'm sure one of the switches went bad.
Old Dec 6, 2012 | 09:29 AM
peterfst's Avatar
peterfst
Default Found the problem
Well, thanks to forum users, I found the problem. A kink or short in the wiring leading from the master switch toward the windows. I'd read twice about this problem, so I checked it out. There it is. I suggest that right after you check the fuse, they should investigate this potential problem.
Peter in SLC
