instrument cluster stoped working.
Old Jan 19, 2013 | 11:23 AM
davisvs's Avatar
davisvs
Question instrument cluster stoped working.
I have a 2001 dodge 3500 van. The instrument cluster has stopped working and shows a bus were the miliage is. This started about a year ago with it only doing it when it was cold out side. I could let van warm up cut off and cluster would work again. You can run the self test and all works during the test but not after. I have removed cluster to see if it was not pluged in good but still does not work. Now the cluster does not read at all even if i let it warm up. does the pcm run the cluster? ever thing elese works in the van and runs really good. just no instruments.
having to us gps on my phone to tell how fast Im going but does not help with gas. I also saw the some of you are talking about broken soilder points on cluster could the be my problem and would the self test still work if it has broken soilder points or is it a pcm going bad. trying to find out before i spend $325.00 on a new pcm and it not fix it. any help would be greatful thank you.
Old Jan 19, 2013 | 11:39 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
The No Bus message means a loss communication between the cluster and the PCM. This could be due to a break in the wiring, a bad connector, a bad cluster, or a bad PCM. Usually if it were the PCM you would also have problems with the engine running correctly. Since turning the key off and on will sometimes clear the problem I believe the wiring is okay. This leaves you with a bad cluster.
Try getting one off eBay or you can search on http://www.car-part.com/ to reach a nationwide network of junkyards.
Old Jan 19, 2013 | 04:22 PM
davisvs's Avatar
davisvs
One thing I forgot is when the van is running the instrument cluster shows turn singals working and hi beam working, abs light, and brake light is on if that makes any differents.
Old Jan 19, 2013 | 10:37 PM
stev's Avatar
stev
There is a way to test the cluster via some operation with pressing and holding something and maybe the key. This was posted before.
Old Jan 20, 2013 | 01:20 PM
alloro's Avatar
alloro
Originally Posted by davisvs
the instrument cluster shows turn signals working and hi beam working, abs light, and brake light is on if that makes any difference.
No it does not. Those items are all direct wired bulbs and do not depend on any electronics to operate.
Old Jan 22, 2013 | 11:11 AM
davisvs's Avatar
davisvs
I have done the self test on the cluster and all works. expect when i drive it. Since I posted this I have had my van shut off when driving always happens when its cold and when I slow down it starts running rough and shuts off. this has never happened before. Now I wonder if its not the pcm starting to fail. what do think? Really hoping to find out whats wrong with this thing since we use it all the time.
Old Jan 22, 2013 | 11:24 AM
alloro's Avatar
alloro
That's more of a PCM issue.
Old Jan 22, 2013 | 11:56 AM
davisvs's Avatar
davisvs
Anybody bought from all computers resources? I found a pcm for may van for $325.00 lifetime warranty and they program it for you. They say remove your old plug in the new and ready to go.
Old Jan 22, 2013 | 03:38 PM
davisvs's Avatar
davisvs
all computer resources also have free shipping.
Old Jan 22, 2013 | 07:43 PM
funair02's Avatar
funair02
I got good service with these guys...
http://automodulesourceusa.com/catal...models=Ram_Van
