Speed Wiring Question.
Old Feb 4, 2013 | 06:27 PM
digdave7's Avatar
digdave7
Default Speed Wiring Question.
Hi, I have a 2000 RamVan 3500 recently changed the radiator fan to an electric on, did notice a difference but it turns on at all speeds if the air conditioner is on, due to the speed and wind you dont need it over a certain MPH.
I know the cruise control wont come on below a certain speed and to save electricity I want to do the same, does anyone know if there is a wire I can hook into to enable the fan and only slow speeds..?
thanks,
david roesch
Old Feb 4, 2013 | 10:08 PM
blackvan's Avatar
blackvan
Old Feb 5, 2013 | 01:07 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Either use the OD wire to trip a relay to interrupt the fan relay power, or install a temperature probe at the A/C condenser that will interrupt the A/C trip wire.
Old Feb 5, 2013 | 01:16 PM
digdave7's Avatar
digdave7
Thanks.. Not sure why I didnt think of the overdrive, since I already hooked into reverse when I added a backup camera(ClassB-RV on Dodge Chassis).
Maybe I'm wrong but I dont think the fan will help driving over 40mph, with both fans burning 60amps, could be saved to charge both batteries(coach / engine).
Old Feb 5, 2013 | 02:51 PM
alloro's Avatar
alloro
Yep, you're wrong, the tipping point is 35 MPH not 40.
