1998 b1500 wheel size
Old Feb 10, 2013 | 12:35 PM
bucketlip's Avatar
bucketlip
New Member
Default 1998 b1500 wheel size
hello, does anyone know if wheels from a late 70's jeep cj will work on my 1998 van?
Old Feb 10, 2013 | 01:38 PM
iodj44's Avatar
iodj44
Contact a tire or wheel shop to confirm but from my experience 5 lug
rear wheel drive Ford wheel fit older pre 1990ish rear wheel drive Mopars
and the offset usually is ok.
Jeep CJ wheels if the bolt pattern is the same you may have a problem
with the offset.
Old Feb 15, 2013 | 09:16 AM
bucketlip's Avatar
bucketlip
New Member
does anyone out there know the stock wheel backspacing for the 1998 b1500? i know i could pull the wheel off and check just thought someone might have the answer. i believe its a 7"x15" wheel and also must have a 3.5" centerbore. thanks dudes
Old Feb 16, 2013 | 10:41 PM
Rusty93RamVan's Avatar
Rusty93RamVan
No, the bolt pattern is definitely wrong.
