94 B350: Brake Line/Nut Size?
Old Mar 4, 2013 | 01:47 PM
daguvena88's Avatar
daguvena88
Default 94 B350: Brake Line/Nut Size?
About redo the brakes on a 94 B350 conversion.
I don't have access to the van right now and need to buy parts ahead of time.
Was wondering if anybody can confirm the flare nuts I'll need for the lines and brake lines diameter.
Below is what i'm guessing...
flare type (Inverted/Bubble) - was thinking inverted
size 3/16, 1/4, 5/16 - was thinking 3/16
thread type - if above, then thinking 3/8-24
Thanks!
Old Mar 22, 2013 | 08:13 AM
daguvena88's Avatar
daguvena88
For those who might stumble across this in the future...
3/16" (3/8-24) flare nuts for pretty much all connections except those at the combination valve (by the master reservoir) which are larger. I just reused the old ones so am not sure what the specs are on those.
Old Aug 27, 2013 | 02:38 PM
daguvena88's Avatar
daguvena88
One of the the proportioning /combination valve flare nuts I reused is leaking. Retightened with channel locks / vise grips but of course they're rounded now. Not sure if that did the trick but figure I outta put in a new fitting and flare.
Anybody happen to know the size of the proportioning / combination valve fitting?
7/16", 9/16"... perhaps chrysler threw in an odd metric 10mm, 12mm?
Old Aug 27, 2013 | 04:12 PM
blackvan's Avatar
blackvan
Old Aug 30, 2013 | 09:35 PM
stev's Avatar
stev
Isn't there some sort of H-block thing where all of the lines run to under the coolant overflow bottle or the batter tray? If I recall, those used a 1/4-NPT.
