1996 Dodge Ram Van B3500 Maxi HD - Air Filter Replacement HELP
Old Mar 25, 2013 | 05:02 PM
autigersfanjc's Avatar
autigersfanjc
Default 1996 Dodge Ram Van B3500 Maxi HD - Air Filter Replacement HELP
Hello,
I just purchased this van and wondering how do you go about replacing the air filter.
ALSO, The side mirrors are loose on the van. Once i get up past 45mph they turn inward. Any help on this issue?
Thanks!
Old Mar 25, 2013 | 06:33 PM
Rusty93RamVan's Avatar
Rusty93RamVan
To replace the air filter the doghouse (inside engine cover) must be removed - see your owner's manual on this. Once the cover is removed you can easily access the top of the air cleaner housing to change the filter.
Loose mirrors is a common problem on your van. Look for a single screw on the bottom of the mirror arm cover. Loosen that screw and lift up the cover to reveal the area where the mirror arm attaches to the door. Tighten both sides of the pinch plate and that will serve to tighten the arm.
Make sure to read the "Sticky" section of this forum -- many questions you have as a new Ram Van owner are already answered in this section without the need to wait for one of us.
