New fuel Pump: will not start
Old Apr 14, 2013 | 09:49 PM
k2nepal's Avatar
k2nepal
Default New fuel Pump: will not start
Hi, I have 1996 dodge full size van 3.9 MFI. Did install a Delphi FG0368 35 gallon fuel pump: Now the van will not start: the fuel gauge does not move; Any advice, please.
Thank you
Old Apr 15, 2013 | 11:13 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Are you sure you connected the electrical plug at the fuel pump.
Old Apr 15, 2013 | 07:54 PM
Bandit2's Avatar
Bandit2
Can You hear the pump running when you turn the key on ?
Old Apr 15, 2013 | 09:58 PM
k2nepal's Avatar
k2nepal
Default Fuel Pump working: but fuel float giving false reading
Now the fuel float is giving a fuel tank, when is not: do I have to drop the tank again or wait to see it is solving by itself.
thank you, for the advise
Old Apr 18, 2013 | 08:18 AM
Midnite12's Avatar
Midnite12
Sounds like you have a short or bad ground? Like Blandit2 said do you hear it run with the key on ? Also does it start ? If so check fuel presure to.
Old Apr 23, 2013 | 10:07 AM
Bandit2's Avatar
Bandit2
will it start ( for a second ) with a shot of either ?
Old Apr 23, 2013 | 07:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Why was the fuel pump replaced? Did it not start before the new one also? Have you tried swapping relays around?
