over head control on Mark3 conversion van
im looking for the overhead switches for a mark3 for some reason it went out i check all the fuses and the wire leading to the control and they both works fine but the control functions just dont work anymore. my battery died and i jump it and all of a sudden the switch dont work anymore. now i found out that its the switch thats blown. i would like to purchase one does anybody know where i could get one or does anybody know the part number for it?
Thanks
Thanks
Try these guys.
http://www.v-sales.com/mark3switch.htm
Or these guys.
http://www.eastcoastautotoys.com/mark_iii.htm
If they can't help you google Mark 3 conversion vans.
Or these guys.
**NO LONGER AVAILABLE* 4 Gang Soft Touch Switch Panel Used in Mark III
Part Number: W-21120025
And I was wondering if there is any other switches I can use or can i just make one. but the only thing is there is only 3 wires behind the swtiches.
http://cpcparts.com/products/details...extProductID=0
Trending Topics
Can you retrofit a switch like this?
http://www.radioshack.com/product/in...ductId=3165064
im not sure. there is only 3 wires on the back on the unit itself. 1remote 1 hot and 1 ground.
I will take pics of it today when i get home from work to show you guys that i dont think its possible for me to even run any other type of switches unless i rewire everything from the tv accent lights dome lights and such.
Ohhh, I though you meant there were 3 wires per switch, not 3 wires for the whole 4 switch assembly. Sorry to say, but unless you can find the exact replacement 4-gang switch assembly, you'll be stuck rewiring the 4 circuits.
