Recharging AC
Old May 24, 2013 | 09:44 AM
Smokey61110's Avatar
Smokey61110
Default Recharging AC
Hi All,
I have a 98 RAM 1500 Van 5.2 liter. The AC isn't working and the compressor isn't coming on. Where do I refill with the R-134? Will it even take it if the compressor isn't coming on? If not is there a way to jump it like I did in my 94 Ford van? Thank you in advance. This is our first dodge van!!!!
Old May 24, 2013 | 12:20 PM
oleman's Avatar
oleman
For all practical purposes the B1500 is identical to a Ford van in A/C operation. Fittings are just in a different place.
The B1500 uses a better designed compressor, Sanden scroll, which also costs more if replacement is necessary.
The most important part of A/C recharge is to pull a good vacuum on the system to get all the air out before you add the Freon. I use a cheap harbor freight vacuum pump but you could be better off to just pay a shop for leak-test and recharge.
If it is discharged completely it is also probably low in oil so expect to have compressor issues in the future.
Old May 24, 2013 | 05:47 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Yes, the R134-a can is pressurized and as the pressure in the system rises the compressor will turn on. Do not jump it out, you will destroy the compressor.
Old May 25, 2013 | 09:04 AM
rsdata's Avatar
rsdata
many repair places are offering AC service these early summer days... for the price that they charge, they can offer a lot of specialty equipment and expertise that might well be worth the expense to find out what IS wrong with your system...
Old May 30, 2013 | 09:13 AM
nibroc's Avatar
nibroc
amen to that!!!
