Upper ball joints
Old Jun 29, 2013 | 08:23 PM
rdweathers's Avatar
rdweathers
Default Upper ball joints
Have a Mark3 1500 conversion van, the front end is 3500lb rating, are the upper ball joints pressed in? The have threads on the outer edge of ball joint, not talking about the shaft that goes into spindle assembly, not sure if this is screwed into the A arm or pressed in. Thank you.
Old Jun 30, 2013 | 01:18 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
It is screwed in and you need a special socket to remove/install them. Your other option is to replace the entire upper arm with one that has the ball joint already installed in it.
