Setting timing
Old Jul 4, 2013 | 12:10 PM
rdweathers's Avatar
rdweathers
Default Setting timing
98 318, what does the timing need to be set at for this vehicle? Does anything need to be unplugged before adjusting? In the old days it was unplug vacuum advance, I know this does not have that. Thank you.
Old Jul 4, 2013 | 03:05 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The timing is controlled by the computer via the crank sensor signal and is not adjustable. Turning the distributor affects the fuel injector timing, not the ignition timing.
