Trouble Code 62
Old Feb 18, 2014 | 09:46 PM
dr76's Avatar
dr76
Default Trouble Code 62
Does Trouble Code 62 have anything to do w/ driveability?
'93 B250, 5.2L
After an incorrect diagnosis that the alternator was bad, and subsequently, that the PCM (which I understand, regulates the alternator) was faulty, BOTH were replaced and now there is a very noticeable miss. Prior to the alternator and PCM replacements, was getting error code "41". Now getting error code "62". Code 41 was cured by repairing a tiny (22ga.?) wire going to the Neg(-) terminal of the alternator.
Since the Check Engine light is NOT on, I'm guessing that code 62 does not have to do w/ driveability...
Could the replacement (remanufactured) PCM cause the miss? Would code 62 have any play in this???
Thanks for input
Old Feb 19, 2014 | 10:30 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Depends, what's a code 62? Are we all supposed to go look it up for you?
Old Feb 19, 2014 | 11:07 AM
dr76's Avatar
dr76
62 = unsuccessful attempt to update EMR mileage in the controller EEPROM
