where would my cps be located
I'm currently working on a 94 dodge ram van and have no spark. The ignition coil rotor has been replaced. Can anyone tell me where my cps would be located also under the hood there is a relay connection witg no rely mounted to the left of the battery does anyone know what this relay may be. I've worked on a simular dodge and the shut down relay was behind the battery but could this possibly be the same relay? Thanks any help is appreciated.
The CPS is the pick-up coil inside the distributor under the rotor. But the CPS only controls fuel delivery timing not spark, so I'm not sure where you're going with that. Unless you're actually looking for the CKS (crank sensor), in which case pull the doghouse off and it's on the passenger side between the bell housing and engine block.
