2 yrs now elec initial start up check engine light flickers 318ci 5.2l 1997
Subscribe
Jul 10, 2014 | 08:52 PM
So where to start
2 yrs ago the first flicker of the engine check light went on some morning in orlando damp winter day after a week of sitting in fort wilderness disney resort camground.
So on to today 2 yrs later the simple toggle the ignition on and off 3 time does not cut it anymore. Usually the check engine light flickers then stays solid and i can start normally
it now takes 10+ try of the key cycle on/off then it start normal and run the whole day just fine until the next day initial start up.
Could it a bad corroded fuse link wire + pos. Cable? And where would i see it by the bat or the starter?
Anyone with a similar solved situation please please contact me i need a solution.
Thanks
joe
ram van 3500 1997 5.2l 175.000+miles all original never opened motor or tranny garage kept
Reply 0
Jul 10, 2014 | 09:02 PM
Most likely your PCM is bad. Since you have to toggle the switch for 10 plus times I would recommend taking a hair dryer to your PCM for about 5 minutes and then see if it starts up normal. If so then replace the PCM.
There is no fuse link on the 97 van's, our vans have a PDC (Power Distribution Center) box under the hood near the battery. All circuits have fuses, while some of the fuses are what is called Maxi fuses (40 amp and higher). Doubt a fuse is your problem.
Reply 0
Jul 26, 2014 | 05:54 PM
no start was moisture in the pcm ecu
thanks to a member of dodge forum
the hair dryer was the right advice worked like a charm
first try.
did the pcm swap and no more issues I keep it on a concrete slab with a roof over but added a small 5" electric fan 115ac 7$ buck wallyworld running off a timer to circulate the air under the hood for the rainy season here in south florida very humid
best regard to the blog
Reply 0
Subscribe
