oil pressure light.
Old Aug 16, 2014 | 08:45 AM
jimbaughan's Avatar
jimbaughan
If the bearings were bad shutting it off and restarting it would not make the pressure return to normal.
Old Aug 16, 2014 | 12:04 PM
SteveR's Avatar
SteveR
The oil pressure light will come on at idle if your van needs a tune-up. You will especially notice this if you stop at a stop-light after a really hard run on the highway. I recall seeing this happen on the highway back when I got my van too.
Regards, Steve
Old Aug 29, 2014 | 12:24 PM
jimbaughan's Avatar
jimbaughan
I have changed the oil pressure sending unit and still have a problem. A manual gauge and the vans gauge both show pressure, but the light comes on. I think the gauge in the dash is bad.
Old Aug 29, 2014 | 10:29 PM
SteveR's Avatar
SteveR
Are you certain it isn't the RPM dropping on you from the engine stumbling? The gauges may have dampening on them and not show fast changes.
Steve
Old Aug 30, 2014 | 09:42 AM
jimbaughan's Avatar
jimbaughan
The light comes on at a steady speed. If I shut it off and restart immediately it goes out.
Old Aug 30, 2014 | 09:47 AM
iodj44's Avatar
iodj44
If the mechanical gauge registers about 10 psi per 1000 rpms you are fine the factory gauge light is faulty. Remember there is a reason some call them idiot lights. I just realized you may not have installed a tachometer so just watch the Mech oil gauge your pressure should not drop below 10 psi at idle.
Old Aug 30, 2014 | 10:52 AM
jimbaughan's Avatar
jimbaughan
never dropped below 15.
Old Aug 30, 2014 | 11:22 AM
iodj44's Avatar
iodj44
In my humble opinion you have nothing to be concerned about, maybe remove the bulb.
Old Aug 30, 2014 | 01:22 PM
jimbaughan's Avatar
jimbaughan
I am going to see if a gauge is available, if not out goes the bulb.
Old Aug 30, 2014 | 06:29 PM
funair02's Avatar
funair02
FWIW The Magnum engine is known to have oil pump failures...
Rockauto show two 'hearts' in the oil pump section. The hearts means they are top sellers...
DNJ ENGINE COMPONENTS Part # OP1140
w/ Standard Volume
$27.79ENGINETECH Part # EP72
Enginetech Pressure pump$29.79CLEVITE / PERFECT CIRCLE Part # 6011083
New Oil Pump
$30.79SEALED POWER Part # 2244166
