1996 ram van 3500 heater defroster actuator questions
Can anyone tell me on a 1996 3500 The heater defroster actuator door: the actuator is rearward of the radio and a little toward the passenger side; one vac line attached and sits vertical; There is an actuator to the left of it but the one I am in question of is the heater defroster actuator;
First do you have to pull the entire heater box out to replace this actuator?? Is the door spring loaded to return??
If you have to pull the entire heater box out to replace : do you pull the entire dash out to do that or is there another way, I have the 1996 book from dodge service manual and it is really not specific on these things, I have had the front of the dash out but no more.
Any info appreciated; And I do understand the leave it as it is, is a big possibility I would just like to fix if possible.
Grumpy
Grumpy
