Lucas oil stabilizer
Old May 28, 2015 | 12:23 PM
rattlecankenny's Avatar
rattlecankenny
New Member
Default Lucas oil stabilizer
I have a long trip to take and my rear diff is kinda noisy. It was all rebuilt about 30k miles ago. Its a 1 ton van, I believe Chrysler rear end. Anyway, Is it okay to use Lucas in a rear diff? I used it in an engine and it foamed terrible. I know these kinds of threads can take off with repair or replace, but that is not an option at this time. If lucas isnt good , is there something I can use ? It's not howling or screaming , just has an audible whine about 70 mph
Old May 28, 2015 | 08:09 PM
landyacht318's Avatar
landyacht318
Nope, Lucas oil stabilizer is true junk that should not be put into anything the owner cares about.
If taking off the diff cover, one can try a boutique gear oil like Redline or AMSoil.
I'd try a high Moly oil in an open differential, but not a limited slip.
Lubro/liqui Moly make good products.
I plan on adding this to my mobil 1 75w/90, right before I go on the next road trip where the diff will get nearly as hot as it gets.
Amazon.com: Lubro Moly 2019 Gear Treatment: Automotive Amazon.com: Lubro Moly 2019 Gear Treatment: Automotive
Schaffers and Swepco make high Moly gear oils. Lots of gear oils have no Moly because it is a friction modifier that will mess with the function of limited slip differentials.
http://www.schaefferoil.com/full-synthetic-lube.html
If my current gear oil was due to be replaced, I'd definitely go with the Schaffers #167.
It is asking a lot for a lubricant alone to change the noise of a differential, and much of the noise that is often attributed to the Diff can be tires or universal joints as the Van body makes it difficult to discern where a noise originates.
