max ac problem
Old Aug 3, 2015 | 01:05 PM
rush1981's Avatar
rush1981
Default max ac problem
have a 98 ram1500 van. max ac blows onto floor. not straight ahead. ac is cold and works on all settings except max. anybody know why it started doing this? thanks
Old Aug 3, 2015 | 09:14 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
You sure it's not blowing out the defrost?
Old Aug 4, 2015 | 12:40 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
When you select MAX on any of the systems, all you're doing is commanding the RECIRCULATION door to close off to outside air. You need to find out what's going on with that actuator or the door. May be a vacuum leak in the actuator or the control head "manifold" where the lines seat.
It appears the vacuum is being diverted the wrong way rather than a leak.
Old Aug 6, 2015 | 05:20 AM
blackvan's Avatar
blackvan
Either the vacuum motor or vacuum line that controls the fresh air door is leaking/disconnected.
Old Aug 6, 2015 | 04:55 PM
rush1981's Avatar
rush1981
does anybody know the general area where the fresh air door is located? thanks for the replys (98 ram 1500 van, mark III)
Old Aug 6, 2015 | 08:09 PM
TNtech's Avatar
TNtech
Far right end of the dash up towards the top of the HVAC case. The actuator is high on the right end I believe.
Old Aug 8, 2015 | 09:27 PM
alloro's Avatar
alloro
Starting in 98 I think it's under the hood right next to the blower box on the passenger side. There is a vacuum actuator there that operates it.
Old Aug 11, 2015 | 11:36 AM
TNtech's Avatar
TNtech
Ok, thanks. We try to avoid anything beyond 98-2000 anymore. Don't see much other than my own 98 Dakota anymore.
