Can anyone physically help me in the East Bay, Northern CA area?
Old Dec 7, 2015 | 07:12 PM
jimbo74's Avatar
jimbo74
Default Can anyone physically help me in the East Bay, Northern CA area?
Need help to perform a leak down test, compression test, and block test
I don't have any of the tools, but should be able to rent them, and/or buy them to do this.
I may have an issue with having a crack in one of my heads, I get multiple cylinder misfires and a cylinder 4 misfire. I also have another issue with my o2 sensor heater circuits and over voltage (both are unplugged right now though, long story, but need to be replaced, I just don't want to replace them, have them go bad because of this other issue, and then have to replace them again)
I do have a very weird schedule, but we can hopefully work something out if you are available
Old Dec 8, 2015 | 09:46 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Check the Services / Automotive section of your local Craigslist.org webpage. Often you will find mechanics looking for side work in that section.
Old Dec 9, 2015 | 12:03 PM
jimbo74's Avatar
jimbo74
That wasn't the point of this post. The point was to see if a fellow enthusiast could assist me for minutes really, and help me get this done. I don't have a lot of $, and the labor rate to take it to a shop is ridiculous, as are inflated prices...
Beer or food could definitely be provided (granted you are over 21 ).
Old Dec 14, 2015 | 12:10 PM
jimbo74's Avatar
jimbo74
ok, so I did the block test and it passed that, I also do not have any signs of any chocolate milk in my radiator.....
next up is the compression test after I let it cool down a little bit
Old Dec 14, 2015 | 03:52 PM
jimbo74's Avatar
jimbo74
Did my compression test.....
Cyl 1: 125 psi
Cyl 2: 120 psi
Cyl 3: 135 psi
Cyl 4: 130 psi
Cyl 5: 132 psi
Cyl 6: 130 psi
Old Dec 18, 2015 | 06:10 AM
blackvan's Avatar
blackvan
Old Dec 21, 2015 | 11:58 AM
jimbo74's Avatar
jimbo74
I did swap the number 4 and 6 fuel injectors to see if that was an issue, 304 and 300 still came back. I did get the rear o2 wired up, still don't have the front wired up yet.
