Won't start after dropping gas tank.
First off, she started flawless every time before this. I had to patch a hole in the top of the tank. I dropped the tank, performed patch, replaced the tank and it wouldn't start. Dropped the tank enough to reach wire harness and wiggled it around and she started up. Turned her off and bolted tank back up. And again she won't start. Dropped her again and took a closer look at the wire harness and noticed bare wire as seen in the pic below. Do you think the exposed wire is the likely culprit? Secondly, can you pull the pin out so I can replace that one wire instead of the whole harness? Would wrapping with electrical tape be a quick fix? I can't find harness locally and I'm stuck at a friends house and have to get the van out of here. I want to be sure before I replace tank back up as it's a pain in the *** without a floor jack and my buddy just had surgery so he's no help. Thanks for all the help guys.
you can usually jsut replace the individual pins....
you may need to get rid of the stripped wire though..... why is it stripped like that?
electrical tape would be fine, or if you have the time, liquid electrical tape. I personally really like liquid electrical tape if I can use it over regular tape
if that wire is direct shorting, that could be why it wont start... seems a little weird though that a wire back at the fuel tank is causing a no start... or is is a no fuel condition?
