Help replacing water pump on 1999 Ram van
Old Aug 29, 2016 | 11:26 PM
nopeda's Avatar
nopeda
Question Help replacing water pump on 1999 Ram van
Hi,
I recently bought a 1999 Dodge Ram van 1/2 ton B1500 5.2L. It seems to need a new water pump since after driving it about 30 miles last week a good bit of coolant was coming out of it, and when I slid under it and looked for the source it seemed to be coming out from the shaft on the water pump. I'm no mechanic but if it's not a really hard thing to replace I'd like to do it myself rather than pay half a paycheck for a garage to do it. Can anyone suggest a good tutorial or video on how to change the water pump on a vehicle like that? Or if it's a difficult project let me know why so I don't make things worse by trying to do the job myself?
Thank you for any help or suggestions!
David
Old Aug 30, 2016 | 06:32 AM
Moparite's Avatar
Moparite
Look on youtube i'm sure there are some posted. It doesn't have to be a van the trucks and durangos have the same engines (depending on year). Snapping one of the bolts is a major issue that anyone may run into doing it. If you do decide to do it yourself get the bypass hose and a new thermostat. May want to look at your hoses also they may need replacing also. Get a good new pump not a rebuilt that has a lifetime warranty.
Old Aug 30, 2016 | 10:17 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
http://www.autozone.com/repairinfo/r...2e2e81#hd1-1-2
