trans slippage
Old Nov 13, 2005 | 06:44 PM
dodge van's Avatar
dodge van
Default trans slippage
1998 dodge ram van 250 trans started slipping, has 120 thousand miles now,start engine put into gear some whinning sounds comming from trans does not enage right away ,foot on brake test and rev engine no engagement until let off the accelerator then the trans goes into gear ,taking off sometimes trans sounds like its reving the motor befor ****fing but the other dasy trans was slipping all together what could be wrong with my trans please help with answers if you can thank you from edd .
Old Nov 14, 2005 | 01:13 AM
draftingmonkey's Avatar
draftingmonkey
Default RE: trans slippage
Welcome to DF. This is the place to come for getting ideas, checking out other peoples rides, asking questions and sharing knowledge. Lots of good people here. Glad to have you aboard.
You really want to post this question in the Ram/Van section. I'm sure someone there will be able to help you out.
Old Nov 17, 2005 | 09:29 PM
Disgorilla's Avatar
Disgorilla
Welcome to Dodge Forum,
Old Nov 20, 2005 | 12:28 AM
ViperGTS's Avatar
ViperGTS
I'm going to move this to the Ram Van section for you.
-Matt-
Old Nov 22, 2005 | 10:07 AM
brandoncrone's Avatar
brandoncrone
ORIGINAL: ViperGTS
-Matt-
Um, isn't this the Caravan/Ramvan section?
Sounds like the front pump is going bad, at 120K time for a teardown and overhaul you torqueflite is getting tired.
Old Oct 12, 2006 | 02:02 AM
tampasailor's Avatar
tampasailor
tranny fluid leves ok?
