MPH to get to overdrive in 5.2 with 46E trans
Old Nov 6, 2016 | 04:24 PM
AmericanMuscle1989's Avatar
AmericanMuscle1989
Default MPH to get to overdrive in 5.2 with 46E trans
Hi all,
New to the forum and my 1995 Ram Van B2500.
It has the 5.2 V8 and I think the 46E transmission but I don't know about the rear gears ratio etc.
My question is, on level ground, minimal weight inside, what sort of speed will it be going into overdrive in as I have no tachometer? Just the speedo, oil pressure, temperature, voltage etc. I feel like everything is working but just wanted to see.
Other info, I have 235/70/16 tires on it.
I have another question re best speed for max fuel millage but I will ask that on another question.
Thanks
Alex
Old Nov 7, 2016 | 09:35 AM
rsdata's Avatar
rsdata
build info usually can be found on a tag on the underside of the hood, drivers side... like rear axle ratio
as I recall, I think mine kicks in around 45 or 50, depending on acceleration/RPM
I also have the same tires, and a 4.10 read end... my best MPG was maybe 14 going 55-60... strong tail winds would bump that up to 15
Old Nov 7, 2016 | 09:40 AM
AmericanMuscle1989
Hiya,
Thanks very much for your response. I will get the number from the under hood tag and report back.
Thanks
Alex
