1994 Dodge 350 van
Old Jan 23, 2017 | 10:52 AM
Robert25's Avatar
Robert25
Default 1994 Dodge 350 van
I want to get the trouble codes for a 1994 Dodge 350 van. Engine light goes on, but if I restart engine, it goes off. Engine stops and restarts intermittent. Thanks
Old Jan 24, 2017 | 10:22 AM
JFloors's Avatar
JFloors
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
There are also youtube videos for a visual if you search something like (read codes 94 dodge 350 van)
Old Jan 24, 2017 | 12:33 PM
rsdata's Avatar
rsdata
I don't think the 94 model had an engine computer yet... looks like they started around 96, BUT all things electrical need good grounds and as old as that van is I would start looking at cleaning up rusted and corroded connections, starting with any/all connectors hooked to sheet metal which provide a ground return path for any electric in the vehicle. ALSO look at connectors to battery and alternator... pull apart, squirt some contact cleaner on it, burnish if corroded and replug... do this with neg battery disconnected
when engine quits does it just DIE, or stumble and die out?
does it quickly and easily restart?
keep us posted
