My high pressure PS hose is leaking
Old Mar 1, 2017 | 03:32 PM
funair02's Avatar
funair02
Default My high pressure PS hose is leaking
It seems like an easy R and R.
Any gotchas?
Thanks!
Old Mar 1, 2017 | 03:41 PM
Just bleed the system real good after you change it.
Old Mar 4, 2017 | 08:38 PM
funair02's Avatar
funair02
Got it done. It went well. A pretty easy job. Not much worse than changing the oil.
All you have to do is remove the Washer and Overflow bottles. That make it for easy access to get at the gear connection. This is also the only way I can see filling the reservoir.
The pump connection was right there when laying under the van.
The reservoir takes one pint. The lower nut is an 18 and upper was a 22.
Glad it is fixed!
Old Mar 5, 2017 | 03:34 PM
JFloors's Avatar
JFloors
Glad to hear it, thanks for the info and update
