Turns over will not run
Old Mar 23, 2017 | 05:57 PM
funair02's Avatar
funair02
Originally Posted by alloro
Do the vacuum test outlined in the TSB, that's the only way to know for sure. Also take a vacuum reading at the intake with the engine running just to make sure it's up in the 20-22 range. If it's not the intake manifold gasket could be leaking at one or more of the intake ports.
Is the 20-20 while holding steady at 1500-2000 rpm or at idle?
Thanks!
Old Mar 24, 2017 | 01:35 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Thanks!
At idle. As the throttle is opened the vacuum should start to drop.
Old Mar 24, 2017 | 05:25 PM
funair02's Avatar
funair02
At idle I have 16 then when I am at a constant 1500 rpm I have 22...
do I have an issue do you think?
Old Mar 26, 2017 | 12:32 PM
alloro's Avatar
alloro
At idle I have 16
Too low, you have a significant vacuum leak.
Old Mar 26, 2017 | 04:55 PM
funair02's Avatar
funair02
It does have 1.7 RR in it...would that make a difference?
Old Mar 27, 2017 | 09:44 AM
alloro's Avatar
alloro
Depends on what a "1.7 RR" is.
This ain't Twitter, feel free to use a few extra letters.
Old Mar 27, 2017 | 02:58 PM
funair02's Avatar
funair02
Seriously? You are losing credibility here.
Every tech know that means "roller rocker"
Old Mar 27, 2017 | 09:38 PM
JFloors's Avatar
JFloors
My vacuum shows 16.5 at idle though no twitter talk mods, lol... Also, this old engine is still eating up about a qt. of oil every 1k or so, The plenum job will be in the near future, just need ambition and time
Old Mar 28, 2017 | 09:37 AM
alloro's Avatar
alloro
Uh huh, okay you go with that.
Old Mar 29, 2017 | 06:35 AM
iodj44's Avatar
iodj44
Not a tech but if you said 1.7 RR to me I would have no idea what you were referring, please just dumb it down so us slow folks can follow the thread.
