how do you lift your van??
I have a harbor freight 1 1/2 ton floor jack. I have to use lumber scraps of all size's .. under my jack stands, and I have to use lumber scraps with the floor jack to get up on the frame to lift the van..
Does anyone have a better way??
use the jack to lift it under the control arm to the height you need, then set your jack stands to the frame with the lumber height needed. Lower the jack easy, move it and use it where needed for extra support.
I have the harbor freight 2 ton low profile floor jack, has a longer lift arm than the others and I've found it less of a fight to get a good angle to clear the handle of the bumper to make the first couple of pumps lifting
