2001 3500 ac
Old May 21, 2017 | 12:06 PM
arty4444's Avatar
arty4444
Default 2001 3500 ac
I recently bought a 2001 3500 maxi without an owners manual. While the ac (front and rear) works fine 95% of the time sometimes the air is not cooled and a breaker behind the glovebox continually resets. But then a day or so later everything works. There appear to be 6 breakers behind the glovebox and the farthest to the right (70 amp) seems to be the one resetting- it gets hot to touch. Before messing with things I wanted to know what those breakers did but without an owners manual am not able to. I can't find an owners manual online and wonder if anybody knows what those breakers are behind the glove box any information would be appreciated. Thank you in advance. I did find a service manual for sale on eBay does anybody know if the service manuals show the various breaker, relay and fuse layouts?
Old May 21, 2017 | 12:38 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
70A? was an electric fan installed behind the radiator for the A/C condenser? If so that's likely the source of the overload.
Old May 21, 2017 | 01:41 PM
arty4444's Avatar
arty4444
The van is a (very) high top "minibus" with many seats and wheel chair lift and was used for rehab transport. There is a double ac fan ("Trans Air") that appears to be part of the minibus conversion ("for FVPP by R D Ward, inc.") added to the bottom outer edge of the van frame behind the driver's door.
Your suggestion does make me realize I may not be dealing with stock breakers but addons I'm not going to find in any manuals.
​​​​​​​Thanks
