Why does flex-a-lite fan fuse blow?
Old May 30, 2017 | 12:53 PM
Dodge_USA_Dude's Avatar
Dodge_USA_Dude
Default Why does flex-a-lite fan fuse blow?
Installed the flex a lite s blade fan with basic flex a lite controller. It keeps blowing the 20amp inline fuse.
It is setup as per instructions:
I have fan negative going to negative battery terminal
Fan positive to controller
Controller with inline fuse to positive battery terminal
From what I read the fan uses 17 amps and the controller hamdles up to 20 amps
It might work once or twice, but eventually blows the fuse. I just replaced the fuse, let it idle and I could here the van like stutter and when i checked it, the fuse was blown.
Any help is greatly appreciated.
Old Jun 1, 2017 | 01:22 PM
Dodge_USA_Dude
Well, spoke to flex a lite tech and the 17amp fan will draw 35amps on start up and the 20amp controller can apparently handle 35 amps so I needed to put in a 40 amp fuse. Go figure.
