I need help please; Headlights
Old Jul 21, 2017 | 08:22 PM
mgoblue9798's Avatar
mgoblue9798
Originally Posted by Obiec
I just purchased a 1988 dodge b250 camper van. I have no headlights. When you pull the headlight dimmer switch on the colum, they will come on. But go out when you let go. It dose not madder if you have the headlight switch on or not. But they will not come on with the headlight switch. I replaced the headlight switch, and that did not help. I would not mind putting in a floor switch for the high lows and getting it off the columb. I need a wiring diagram? Or? I did see something about (Jim Lane's head light harness upgrade), but I can't find it anywhere. Please help if you can.
My 2002 had burnt wires at the headlamp switch in the dash. Might look there. Mine was obvious once the switch was taken out as the wires were brittle from the heat.
Old Jul 21, 2017 | 08:26 PM
tjkoko's Avatar
tjkoko
The headlight switch on the dash can get awfully hot and it might be a good idea to replace it.
