2000 Dodge ram 1500 van oil sending unit switch
Old Mar 17, 2018 | 09:21 PM
Lucig66's Avatar
Lucig66
Default 2000 Dodge ram 1500 van oil sending unit switch
I need help with a 2000 Dodge ram 1500 van oil sending unit switch
does someone know where its located this switch for this specific 2000 Dodge ram 1500 van,
It will be helpful if someone has the instructions to change this switch with pictures or a video
Thank you guy's for your time.
Old Mar 18, 2018 | 12:17 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Remove the engine cover and it's right there next to the distributor. Remove the electrical connector, screw it out, screw the new one in, plug the connector back on. That's it!
Old Mar 19, 2018 | 05:14 PM
Lucig66's Avatar
Lucig66
Thank you for the help I'm going to try to do this Saturday thanks for the help.
Old Mar 20, 2018 | 11:13 AM
alloro's Avatar
alloro
Be sure to clean the area around the sender before removing the old one. Since that passageway is after the filter you don't want any debris to fall into the hole.
