2001 Dodge Ram 1500 Van 3.9 V-6
Old Dec 22, 2018 | 12:40 AM
Wilddawg62's Avatar
Wilddawg62
Angry 2001 Dodge Ram 1500 Van 3.9 V-6
Having a major problem with the charging system. Replaced both Battery and alternator. Still doing the same thing, won't Charge at volts it should be. And then after driving for a few minutes m it will drop to nothing. Could the Computer be the cause?
Old Dec 22, 2018 | 10:39 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Yes, the voltage regulator is built into the PCM.
Old Dec 22, 2018 | 04:02 PM
wca_tim's Avatar
wca_tim
have you carefully checked and cleaned all the associated connectors, grounds, etc...? Checked for shorts in the electrical system? I know it's obvious, but I've overlooked those things a couple of times in the past...
Old Dec 27, 2018 | 11:35 PM
SteveR's Avatar
SteveR
I would read the computer for codes. It should tell you if there is a problem with the alternator field.
