1999 Dodge Ram Van 1500 Cruise Control
Old Mar 3, 2019 | 06:39 AM
floridacruiser's Avatar
floridacruiser
Question 1999 Dodge Ram Van 1500 Cruise Control
I have a 1999 Dodge Ram Van with the V-6 Automatic transmission I bought new. It only has 39,000.0 actual miles. When I put it on cruise control at any speed, it feels like a quick in the blink of an eye stumble. It doesn't kick off at all and continues on cruise. If I don't use cruise there are no problems whatsoever at any speed. Runs steady and smooth as it should.
Is there something in the cruise setup that I can look for causing this problem? Thanking you in advance for your suggestions.
Old Mar 6, 2019 | 07:45 AM
ramvan61's Avatar
ramvan61
If you have not already done this, I would check for error codes to see if the cc is malfunctioning in anyway. Cruise control vacuum reservoir and vacuum leaks could be problem areas to look into.
Old Mar 6, 2019 | 04:19 PM
floridacruiser
Thumbs up Thank you
I'll check it out when I get a chance. Thanks for responding.
Old Jul 25, 2019 | 03:20 PM
Joe King's Avatar
Joe King
Ignore post, not relevant
