2000 Dodge Ram Van 1500 Camshaft Position Sensor help
Got the P0016 code off the check engine light last summer (camshaft position sensor). Symptoms seem to match: couldn't drive past 60 mph because the van wouldn't shift gears properly. Happened pretty consistently on days when it happened, then if I turned the car off and back on it would sometimes go away. And even though I'm not seeing this issue directly right now, my gas mileage is also really bad (got 8mpg off my last tank.) So I think something in the fuel system is a little wonky.
Seems like a pretty simple fix, except that I can't seem to find the part anywhere online (and o'reilly couldn't find it either)... does anyone know why? Or next steps I can take here? My friend and I are going to dig in and see if we can find the sensor under the hood tonight. more details: 2000 Dodge RAM 1500 Van 5.2L FI OHV 8cyl Thanks everyone! |
Originally Posted by jmondo
(Post 3432656)
Originally Posted by ramvan61
(Post 3432693)
Distributor Pick-Up Coil maybe what you need.
