Dodge B350 Fuel Filler Neck
Old Oct 2, 2019 | 02:48 PM
GoingGrey's Avatar
GoingGrey
Default Dodge B350 Fuel Filler Neck
Got a Dodge B350 Van (5.9 motor) that was involved in an accident that tore out the whole fuel filler assmbly (cap, vent tube, hose, clamps, etc).
I have searched all over the internet and local auto wreckers and cannot find a replacement (no OEM, no after market, nothing).
The man who owns this vehicle is a retired senior who has been surviving for years in this van.
Any ideas? I'd love some part numbers if possible. All I have is the service manual.
Thanks in advance.
Old Oct 2, 2019 | 08:35 PM
ElkCon's Avatar
ElkCon
did you try car-part.com
There a tons of vans in wrecking yards..the issue is just finding the right ones.
I have found many in FL, PA, GA, TX and many other places.
There is a couple of the early model ones in the junkyard a mile or so away from me.
Old Oct 2, 2019 | 10:01 PM
GoingGrey's Avatar
GoingGrey
Yes. Only one hit.
We've jury-rigged a solution for now and will keep an eye out for a more permanent solution.
Old Oct 5, 2019 | 03:08 PM
wca_tim's Avatar
wca_tim
What year? I just added a 35 gal rear tank from a 97 to my 99 (original mid way forward off center) and used a new factory fill for a 97 that I ordered... The fill tube changed several times depending on which tank and year (tank location, etc...).
Old Oct 5, 2019 | 05:28 PM
GoingGrey's Avatar
GoingGrey
Van is 1984 Dodge.
Old Oct 6, 2019 | 03:15 PM
wca_tim's Avatar
wca_tim
that's earlier than the model I used... but it may well be that the 94-97 fuel fill (from when the tank was still in the back) will work. I used that one with a rear mount fuel tank in my 99 and it fit just fine for my use. wasn't ridiculously expensive from rock auto... Honestly, I would bet pretty much any thing that'll mount up to the well on the side (if it's still there) will work... you can always order the right diameter marine spec fuel fill hose to fill any space you need to... and use a fill out of a truck or something. shouldn't be a huge deal... I took pics with a ruler of the one I have if you need dimensions...
