oil pressure gage reading 0
Old Dec 9, 2019 | 04:31 PM
Dodge01hgm's Avatar
Dodge01hgm
Default oil pressure gage reading 0
2001 5.2 318 . Oil pressure gauge 45 psi, dropping down to 20-30 psi, than at times to o psi. replaced sending unit, same problem. No noise from engine when oil psi reads 0 psi. Any ideas? I have heard that older 5.2 engines are know for the oil pump screen to clog up and restrict flow. I was told to take off oil filter and blow compressed air unto filter housing using an adapter in place of the filter
Old Dec 9, 2019 | 10:01 PM
ElkCon's Avatar
ElkCon
Ive heard of fixing that sender is supposed to fix the issue.
The pumps are known to get weak, but I would try thicker oil too.
Id like to know this issue if I ever have this issue. Hopefully someone else can add more
Old Dec 12, 2019 | 08:49 PM
wca_tim's Avatar
wca_tim
first thing I would do is connect a mechanical gauge and see what your oil pressure really is.... I had a sending unit go bad in one of my ram trucks 5 or 10 years ago... it happens...
Old Dec 12, 2019 | 08:59 PM
Dodge01hgm's Avatar
Dodge01hgm
Has a new sending unit, i put in a mechanical gage today. I put sea foam in oil 50 miles ago, seems to be better.I am thinking its carbon blocking oil intake to pump.
Old Dec 14, 2019 | 08:09 AM
Dodge01hgm's Avatar
Dodge01hgm
UPDATE - 150 miles with Sea Foam in oil. No problems with oil pressure yet
Old Dec 14, 2019 | 05:07 PM
Dodge01hgm's Avatar
Dodge01hgm
UPDATE - 200 miles, oil 40 psi ,, exited freeway , now doing 35 mph, oil drops to 20 psi and stays there. Increased speed to 50, oil still at 18-20 psi. Drove for about 4 miles pulled over and turned off engine, restarted ,, oil psi back to normal. Third time its done this in couple weeks.I am thinking oil pump relief staying open , not closing, to increase pressure
Old Dec 27, 2019 | 09:03 PM
Dodge01hgm's Avatar
Dodge01hgm
UPDATE ,,,poured in Seafoam oil treatment and still had problem after 300 miles,,, removed oil pan and the oil pump intake screen was almost completely restricted with a hard black carbon,, installed new pump & intake tube/screen, all good back to normal oil pressure. 115,000 miles on engine,,,new oil & filter every 6000 miles with Valvoline Syn 10W30 & Mobil one filter
