Heat/AC Only Blowing Through Vents on Max AC Setting
Old Nov 14, 2023 | 07:08 PM
tteckels's Avatar
tteckels
Default Heat/AC Only Blowing Through Vents on Max AC Setting
Hi.
New here.
We have a recently purchased 1999 Dodge Ram 1500 Van and the heat/ac are both working as blower and temp controls work fine. Problem is vents only work on Max AC setting.
Guessing that switch/controller is bad. Anyone happen to have a part number or link to replacement?
Old Nov 15, 2023 | 11:44 AM
jeffersonracing's Avatar
jeffersonracing
Could also be a problem with the vacuum lines or diaphragms that control the flaps.
Old Nov 16, 2023 | 09:05 PM
BlockHeadGearBender's Avatar
BlockHeadGearBender
Part numbers can usually be found poking around in moparpartsgiant.com
https://www.moparpartsgiant.com/part...rol_hevac.html
[edit: alloro has a better answer.]
Old Nov 17, 2023 | 08:02 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
A loss of vacuum to the HVAC system causes the airflow to default to the defroster position. Since the air is coming out of the vents and not the defrost, either a vacuum actuator or the air flow selector switch is likely bad.
