2000 b1500 Brake and ABS lights on
Old Apr 13, 2024 | 03:58 PM
OregonApe's Avatar
OregonApe
Default 2000 b1500 Brake and ABS lights on
Hi all, so since I bought this thing last year the Brake and ABS lights have been on. I found a guide somewhere on this site about disconnecting the battery to reset things and whatever that did changed it so that instead of coming on at startup and staying on, they come on, turn off, then about 30 seconds later come back on whether I am in park or drive.
This morning I went out and changed the speed sensor on the diff and then did another reset and nothing has changed. I also don't seem to have ABS based on the hard stop and skid I did a couple days ago (darn physics).
Suggestions?
Old Apr 13, 2024 | 05:44 PM
jeffersonracing's Avatar
jeffersonracing
Not sure if it applies to your van, but some vehicles will trigger that light when the brake fluid is low. You might check that and then get the codes read to find out more.
Old Apr 30, 2024 | 01:02 AM
OregonApe's Avatar
OregonApe
Not low here. I have seen that on Nissans where it would give a traction control warning if brake fluid was at all low.
