920, 921, 999 no bus intermittent
Old Nov 10, 2024 | 02:44 PM
robertelmblad@gmail.com's Avatar
Default 920, 921, 999 no bus intermittent
2000 ram van 1500 5.2 motor 163,600 miles
was running fine with no problems until after sitting for several months without being driven or started. No it has the intermittent no bus on odometer display and won’t start when displayed or dies when running. Sometimes will start right back up, other times it has to sit for a while. Sometimes it runs without any problems and then after shutting it off it does the no bus thing. Don’t understand how this happened just from sitting unused for several months and not sure what the codes mean as I’ve seen a few different definitions for what the 920 and 921 codes are.
Old Nov 11, 2024 | 06:42 AM
ElkCon's Avatar
ElkCon
I believe to fix that 1. (easy) take out t he cluster, clean the connections and put it back in...or 2. you need a new cluster
@alloro has a lot of experience with this one - let's hope he/she chimes in
