Unstable RPM while in park
Old Dec 27, 2024 | 10:21 PM
MKMcDonough's Avatar
MKMcDonough
Default Unstable RPM while in park
Hi gents,
On my 2000 Ram Van, while in park, my RPMs kind of fluctuate. I haven't gotten the chance to poke around on it to see if I could come up with a theory, but I thought I'd hop on here real quick to see if anyone had an idea where to start.
It doesn't seem to have the issue when idling in drive... only while in park.
Any ideas?
Thanks in advance,
Matt
Old Dec 28, 2024 | 08:32 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
This happened to me this past summer. I replaced the TPS, reset the PCM, and the issue went away. This can also be caused by a vacuum leak, which I did first check and did not have one.
Old Dec 28, 2024 | 11:13 PM
MKMcDonough
Thanks!
I have a spare IAC valve, but not a TPS. Maybe I’ll replace both just to be sure to cover bases. I guess I need to check for vacuum leaks too.
Is there a less redneck way to check for vacuum leaks besides the old “spray hoses with starting fluid and see if it idles up”?
Old Dec 29, 2024 | 08:20 AM
alloro's Avatar
alloro
Yes there is:
Amazon.com: Kuntech Automotive Smoke Machine Built-in Air Pump, 12V DC Smoke Leak Detector for Pipe System, Fuel Leakage, Leakage Diagnostic Tester for All Cars : Automotive Amazon.com: Kuntech Automotive Smoke Machine Built-in Air Pump, 12V DC Smoke Leak Detector for Pipe System, Fuel Leakage, Leakage Diagnostic Tester for All Cars : Automotive
