What size tires will fit?
Old Jan 18, 2026 | 01:12 AM
Stinky123's Avatar
Stinky123
Default What size tires will fit?
ON my '78 B300....it had 225/75-16s on it. It needs tires and I was planning on putting old tires from my Suburban on it...245/75-16s on it. I see evidence that the old ones rubbed, just a bit in front. But, I really don't know if it was the old ones, or others.
Theoretically, what size tires will fit the van, in front, w/o rubbing? I assume that the rear will handle the 245s w/o issue.
Old Jan 18, 2026 | 06:52 AM
Go to discount tire website, enter your vehicle information and it will tell you what other sizes you can run on a stock suspension.
Old Jan 18, 2026 | 05:11 PM
Stinky123's Avatar
Stinky123
I went to the Discount website. It would seem that in 1978, based on their tire finder, Dodge only made Chargers and Challengers.
The les schwab, discounttire, tirerack dont work on a 1978 vehicle. 1980 tends to indicate 8.75x16.5. But, that is not the same generation of van.
I think that we are gonna put 225/75-16 on the front and 245s on the rear.
Old Jan 19, 2026 | 06:51 AM
Should be fine. That's about 1" taller and 1" wider.
https://tiresize.com/calculator/
Old Jan 19, 2026 | 07:28 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
According to this website, for 16" rims, 225/70R16 and 235/70R16 are the two sizes that will properly fit your vehicle.
https://tirediscounters.com/collecti.../Submodel/Base
