ecm fuse blowing
Old Jun 27, 2006 | 10:36 PM
99blueram's Avatar
99blueram
Default ecm fuse blowing
Hello, I have a 1997 5.2 2500 ram van that keeps blowing the ecm fuse in the fuse box in the dash compartment. Let it sit a couple of hours and put a fuse in and it started. Now i can't trust it because of the possible shutdown when the fuse goes. So i was wondering if anyone out there has had a similar problem and how it was corrected. Thx in advance.
Old Jun 1, 2007 | 03:55 PM
simpacheco's Avatar
simpacheco
Default RE: ecm fuse blowing
ive got the same problem #9 fuse keeps blowing on me every time i turn my key to the start thought it was my ignition switch replaced that nothing so im just as lost if you get anything let me know ?
Old Jun 1, 2007 | 04:22 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Perhaps your ECM is internally shorted.
Old Jun 1, 2007 | 06:12 PM
simpacheco's Avatar
simpacheco
well i traced the wire back to the purge valve connecter and it was the purge valve ounce they go they tend to blow the fuse i would check that.let me know how you did?
